Hello everyone,
I am starting this new project and I want to use Capella for the modelling part. However, connexion of the modal to a database is essential for the project.
I woul like to know if it is possible to connect a capella model to a database (MySQL for example)?
Thank you in advance for your answer.
What is the goal of connecting your model to a database? What do you mean by “Connecting it to a database”? (all the model elements? diagrams as well? Live/instant connexion synchronisation of all Capella users or asynchronous connexion run by a user action? To a specific database schema?
Stephane LACRAMPE
Obeo Canada
Hello Stéphane,
Thank you for your reply.
By connecting to a database I mean the model (all model elements ideally) connect to a database, retrieve some data. For example, At some point, I want to connect the state in the state machine diagram to a Database (MySQL), which ideally means when the “system enters a state” it has to “connect to the database” and retrieve some data.
Ah ok, now I understand. I see 2 ways of doing this:
- either by developing some specific Java in an Eclipse plug-in for managing
- or by using the Python4Capella addon. Not sure if this is feasible from scratch with this add-on but there are probably ways to connect to a database with it - https://github.com/labs4capella/python4capella
I hope this helps
Stephane LACRAMPE
Obeo Canada
I will look into it.
Thank you very much.
