Hello, I am facing two issues with my Capella modeling, which I guess could be related. Your suggestions will be very helpful.
- I created a data model and all my EI in a [CDB]Class Diagram Blank at Logical level. Since this falls in the Common diagrams category, I was under impression that these EI should be available to me across different levels, including System level. But I don`t see any in the list when I try to insert exchange items at System level. Any ideas as to why?
- I have started my model from System Level to Logical and Physical. Now, when I try to go back to Operational level and create any models, the links in the workflow don
t work and I can
t create any diagrams. Is this normal or there is an issue with my files?
*Sorry for my lengthy post, I hope I stated my problem clearly. Thank you in advance for any ideas and suggestions.
