Hello everyone,
I’m trying to add requirement Metadata, but it cannot be added, I click on (Operational Analysis > Add Capella Element > Capella Types Folder) and nothing happens after it. Knowing that I have already managed to create Capella module that contains Requirements.
Thank you
Hi. The Capella Types Folder is hidden by default. You can show it by deselecting the filters:
Thank you, that was exactly the problem, I have found 10 Capella Types Folders after disabling the filtre, because I’ve been adding it for so many times without success. Thank you once again.
