Hi all,
I try to work with Capella element (diagram) as byte array in java.
For this case I use CopyToImageUtil from eclipse.
org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil
Example of code:
Diagram diagram = (Diagram) element;
byte[] pngDiagram = copyToImageUtil.copyToImageByteArray(diagram, 800, 800, ImageFileFormat.PNG, new NullProgressMonitor(), PreferencesHint.USE_DEFAULTS, true);
On big diagram copyToImageUtil.copyToImageByteArray freezes and Capella does not response.
Is it a right way to get byte array of the diagram?
Is anyone faced with such problem?
Thank you,
Egor
