Thank you for your anwser!
I don’t understand which element can be a CapellaElement in my case…
I present you my objective :
I have built a new element via a viewpoint : Multiplicity. This element is available through RMB on a Actor.
In my model, I have other attributes on my actors that called MULITPLICITY but they are made with IntegerPropertyValue configuration.
The viewpoint has Rules. When the rule is launched on an actor, I want to scan the project and find out each MULTIPLICITY present on every actors (not only the selected one).
So I want to build a list of all Actors and work with this list to replace MULTIPLICITY (“integer property value” instance) by a MULT (“multiplicity” instance)
My questions are :
- Am I right to want to do this in the Rule (“run” part)? If not, where should I do this?
- what can be the CapellaElement in my case?
Do you understand what I want to do?
Thanks!
