[Bug] Model Detachment does not Work
Model Detachment fails to remove references to deleted libraries.
Video showing the bug: Capela 7.0.0 Bug - Model Detachment does not work
Version: 7.0.0
Build id: 202407091438
Windows 11
Confirmed on my end, you can raise a ticket I think.
Workaround may be to re-create these libraries with the same name as empty libraries and then remove the libraries dependencies through the usual library dependencies functions.
Or edit the .capella file by end…
In any case, save your project wisely before.
Thank you for the response and workaround.
I’m new here, so, just to be sure, raising a ticket means creating an Issue in the Capella github repository, right?
And is this forum the correct place for bug reports like this one? Or should I directly open issues on github without creating related forum posts? I’m afraid to be spamming the wrong place with requests.
Yes, the GitHub repo is the right place to create issues.
And yes I think raising your issues first on the forum is a good idea. It helps to make sure that this is really a bug and I think you’re going to have more reactivity here than in the github issues.
Great. I’ve raised a ticket on github.
Thanks,
Mateus
