I’m trying to create a breakdown of operational activities , means inside of Root Operational Activities
if False:
if False:
if False:
project_name = aird_path[0:(aird_path.index("/", 1) + 1)]
project = CapellaPlatform.getProject(project_name)
model = CapellaModel()
model.open(aird_path)
model.start_transaction()
oa_pkg = se.get_operational_analysis().get_operational_activity_pkg()
try:
for activity in se.get_all_contents_by_type(OperationalActivity):
if activity.get_name().startswith("Root"):
oa_name='oa test'
oa=OperationalActivity()
oa.set_name(oa_name)
activity.get_owned_operational_activities().add(oa)
except:
model.rollback_transaction()
raise
else:
model.commit_transaction()
model.save()
but that get error AttributeError: 'OperationalActivity' object has no attribute 'get_owned_operational_activities'
Then I’ve tried with activity.get_java_object().getOwnedOperationalActivities().add(oa.get_java_object()) and that get error
_pyease_string_types = (basestring,)
File "C:\Tools\Capella 5.2.0\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\java_gateway.py", line 1321, in __call__
File "C:\Tools\Capella 5.2.0\plugins\py4j-python_0.10.9.5-bnd-2odeag\src\py4j\protocol.py", line 330, in get_return_value
raise Py4JError(
py4j.protocol.Py4JError: An error occurred while calling o42467.getOwnedOperationalActivities. Trace:
py4j.Py4JException: Method getOwnedOperationalActivities([]) does not exist
at com.sun.proxy.$Proxy56.executeScript(Unknown Source)
As I understand it, it is necessary to trace operation_activity with owned_operational_activities, but I don’t know how exactly to do thi.
Manually we can add an operational activities inside other operational activities. In physical component we can do this , that I’ve tried to replicate but it doesn’t works. Does anyone have any idea how to create an operational activity inside root?
Thanks in advance
