We have more than 4,500 logical functions in one project in Capella 5.1. When we try to “Perform an automated transition of Logical Functions”, the “Functional Transition” dialog can pop up. But when we click the “Apply” button, the dialog will disappear, and nothing else will happen. No Physical Function is created. Does anyone know how to solve this issue? Thanks in advance!
I tried it on a model with a similar number of functions, and it worked. It was on Capella 5.2.0, though. Any error in the error log for you?
You may try a few things:
Check the memory parameters in your Capella.ini
Close your session re-open it and try the transition again
Run the transition on smaller subsets of functions (select functions, right-click and choose Transition)
obvious one, but make sure you click on Apply and not OK
I reproduced your issue. Would you please raise a bug on the Capella Github, with your model attached?
Not knowing the underlying technical reason, I am still confident that the main reason why you are having this issue is that all your functions are at the same hierarchical level. I took your model and grouped your functions by package of 1000 functions (in other words: I now have 6 high level functions that have 1000 sub functions for each one of them) and the transition works. So this is probably an idea for a workaround for you.
I had the same problem with much smaller models. I think that the problem not with model size. You need to run model validation. It will show you some problems with the model that should be solved before doing transition. Only technical issues on EObject level need to be solved.
Has anyone been able to understand this issue and either how to resolve it or work around it?
I’m in the same position where I can’t transition between any of the layers. The window pops up identifying all the differences between the model layers and when I click “apply” the window closes and nothing seems to happen.
I do have model validation warnings, but no errors. W.r.t. @dsryzhov comment above, I’m not sure what is meant by “EObject” technical issues and so don’t know if this is something I can do to help fix it.
So I think I’ve found the direct cause of the issue and a work around.
It appears that the basic mass, performance and price viewpoints were causing the issue for me.
When I unreferenced them, I was able to perform automated transitions once again.
I am using Capella 6.1, and I can also confirm that Mass, Performance and Price viewpoints are causing this issue. I can also confirm that all three viewpoints have to be unreferenced for the transition function to work properly, i.e. if any one of them is referenced, the Transition function breaks.
I struggled for 2 hours and nearly broke my model before I turned to the forum to find this answer. My model only has 30 functions!
Is this bug fixed in Capella 7.0, or is this a Mass, Performance and Price viewpoint related bug?
