I am trying to make a simple allocation using the requirement viewpoint.
I used the help contents and performed the 3 steps to allocate a requirement to an object.
Once the allocation has been made, I want to view the requirement allocated to a component using the mass visualization view, but I do not see the allocation information.
It may be a problem of displaying the name of the requirement, the same in an allocation matrix, it looks like the requirement is well identified (1 column) but the name is not displayed.
I would also like more information on Capella’s ability to realize allocation matrixes (with the requirment viewpoint) in order to be able to carry out allocations directly via the matrix or to display allocation links automatically, in the way from Cameo.
(I use the last Capella 1.4.0 version with the last add-on version)
Thank you in advance.
