I was wondering if there exists a way to quickly hide/show Capella model elements based on their applied properties (added using the PVMT add-on).
As an example, if I had an enumeration property for component exchanges with the enumeration literals: Pressure, Temperature, and Flow, would there be a way to quickly hide/show the exchanges on a diagram based on this property (i.e. show only the pressure exchanges)?
Thanks in advance for the help.
Zach
