Hello all,
I try to run M2Doc with projects that contains Capella project and Capella library, it doesn’t work.
M2Doc always returns NULL:
Do you have any idea what it is?
Kinds
Hello all,
Kinds
Did you change the .genconf file to reference the new model ?
If your model contains architectures they should be returned. Capella libraries are provided using extensions, and I don’t see how it could affect the behavior of AQL and M2Doc.
I found out what the problem is. The project is in a Library. when it should be the Library that should be in the project
