Gathering of computed physical links
Hello everyone,
Is it possible to make appear a “computed” category ?
Let’s say I have 3 elements linked to the same Physical component, like in the picture:
If I get the 3 components of my diagram, I will have three computed physical links:
I have created a category that gathers the three physical links. However, I can’t make it appear on the diagram if the three physical components are not present ! (when the physical link are computed, the category does not appear in the “Switch Category / PL” wizard).
Do you know if it is possible to gather the computed physical links in a “computed category” ?
I think this question is not related to document generation, you might have more luck getting an answer if you post it in the main Capella forum:
https://forum.mbse-capella.org/c/capella/19
