I’m having difficulties accessing the progress status of my diagram.
The goal is to display the progress status and review (see image 1 below) inside the title block using a “feature command” or a “aql command”
Is the progress status not a diagram feature like the documentation for example ?
(For a given diagram: the line “feature:documentation” returns the description of the diagram)
Thank you in advance for your help
It is possible, but the formula is a but complicated.
I managed to do it on a similar case using the following: aql:self.eAnnotations->select(a | a.source = ‘http://www.polarsys.org/capella/core/ProgressStatus’).references
For a more detailed technical explanation, you can have a look at that post in Stack Overflow: https://stackoverflow.com/questions/59457543/how-can-i-access-to-the-dannotation-eoi-of-a-diagram-elements-of-interest-with
Martin Le Bourgeois
ObeoSoft Canada Inc.
Hello Martin,
Many thanks for your prompt reply.
Your suggested solution works perfectly as described
Hassene
Also, in order to retreive the text from the Review text space, the following formula can be used:
self.eAnnotations->select(p | p.source=‘http://www.polarsys.org/capella/core/StatusReview’).details.value
Best regards
Hassene
